Installing a Wideband question
I have a PLX Wideband with 2 1/16 inch gauge im going to be installing soon. I am gonna weld in a O2 fitting on the Y-pipe to install the sensor there. My question is where is the best place to route the wires from the O2 sensor to get them into the passenger compartment so i can hook it up to my gauge, etc...
Thanks
Thanks
Thanks
Thanks
cut a hole in the rubber shifter boot under the center console and run it through there. I have my wideband wires, nitrous wires, and nitrous lines all running through there. Very easy to run through there too.
I would run the wire up under the PCM and in through the grommet that the system wires run through.
This is how most of mine is done... you will have to remove the computer and passenger's side kick panel.
