99-00 complete conversion need help w/ vats
just took motor and transmission wiring and computer out of wrecked 99 ls1 and put in 00 ls1 now it will only start for a sec then die.... think it's the vats how can I bypass it... also since I'm using the 00 key and the 99 pcm can I still bypass it manually?
What kind of vehicle?
If a LS1 F-car, you should be able to run either pcm, without issue. Since the resistor key just makes the BCM send a enable signle to the pcm, so the pcm does not know what key you are using.
IF this is an a Y car, then the key must be correct, since they use a different vats system.
Ryan
Ryan
This is for earlier cars, but the principle is the same if you want to try a differrent resistor - http://shbox.com/1/vats_bypass.jpg
