Can I swap computers
I am in the process of putting a motor from a 1999 Camaro into a 2001 Camaro roller. I have the computers for each year. My 99 computer is set up with VAts delete, Second O2 delete Skip shift delete and works good with the motor that I'm putting in. Can I just replace the 01 computer with the 99? Or is there a difference between the years?
They will interchange just fine. Just use the wiring harness for whichever computer you use. If you use the 99 computer with the 01 harness, you will set a cel because of the egr.
Originally Posted by wait4me
The programming will be incorrect, It has different injectors and several other things that need adjusted for that. I can update it and take care of the other stuff for a very reasonable price if needed.
