Would someone be willing to look over my tune...
... and see if I did everything OK? I modded my 91 TPI chip myself, but for some reason this one seems a bit harder lol I know it shouldn't since it's virtually the same software code... Anyways, if someone would be willing to, that would be awesome. I'm basically shooting for AIR and EGR to be OFF and get a little more oomph out of the car. I did basically the same things as my TPI, mod the VE tables and spark. I use TunerPro, and if you load both of the BINs up and use the compare feature you can easily see what I've changed, and to what.
ftp://arctec.org/public_html/93LT1/
I have CAI with Vortec smooth intake elbow, BBK 58mm TB, just installed 24# Ford blue top injectors (read on a site they run on lower PSI, so in a GM they run higher PSI which I accounted for), SLP Dual-dual exhaust with factory Cat (which can be removed if there will be better power gains after tuning), and in the near future I'd like to install my souped up 700R4 (same tranny I have in currently) and an adjustable fuel pressure reg. So if the VE tables need to me adjusted more or less for the higher/lower fuel pressure please let me know.
Also, if someone has a Corvette PROM dump from 92/93 I'd love to get ahold of it and compare to mine. Or even a 94/95 F-Body, if the flashable PROM can be dumped.
Thanks! Feel free to ask me questions, any and all.
Where's the files section on Moates?
EDIT: Well I found it, by dumb luck adding /files/ after .net
Anyone know what the name of the 93 Vette Chip is? :\
