Low oil light
Low oil light
I am consistantly getting a low oil light and my oil level is fine. I look down at the oil pan and see no wire attached to the sensor at the bottom of the pan. Do I need to be searching for a connector to attach to his sensor? If so is this a connector on the engine harness or the chassis and what is it nearby?
2001 Camaro M6
2001 Camaro M6
Should be a connector coming from the harness to the sensor on the passenger side of the pan. Can't tell you exactly where it branches from the pic in my helms, but looks like from the top/towards the front.
