Crane/Vinci Tune + Boost ????
i am in the finishing stages of completeing my rear mount turbo setup
it is a forged piston, stock block, crank, cleaned up vj heads scr is 9.5:1
ls7 clutch set, steel shift fork t56, etc., stock rear and gears
turbo is mp t70 t3, fmic,
ls6 int., ported tb, truck coils, ngk tr55, msd wires,
stock ported manifolds and 2.5 tubing with no cats,
i have the crane/vinci tuner that i bought earlier this yr for the car 02 SS
will it be able to tune for 5-10 psi and run a pretty safe tune, i am also using 42 svo inj, and return fuel sys., with aeromotive 1:1 refernced regulator
its a dd street car and will prolly only see occasional track passes
looking to make 500+rwhp
i would like to know any users results with the tuner and boosted engines,
i have this tuner alredy, and it claims to be able to support boosted appl.
will i have to use a 2 bar map sensor or will the stock map sensor be fine for
less than 10 psi?
please post if u have any feedback or similiar results
also i have stock cam but will install a 02' z06 cam later
thanks
less than 10 psi?
thanks
no help because im a noob
i cant be the only **** running boosted with this tuner, i know somebody
can give me some advice, i bought the tuner from a sponsor on here, and some other member told me that there is a guy real knowledgeable about the crane/ vinci tuner and he even helped develop it or something like that
have gone thru the search button and website, but most of the stuff is
irelevant or not any helpful
Originally Posted by foff667
Although the vinci unit is more flexible then most handhelds I still wouldnt trust it for any boosted application.
If you have the chance I would sell it & buy yourself a true VCM suite such as hptuners or efilive.
i just figured thats what i need to do, seeing as how ther is little to no support for this contraption, even though it advertises and claims to fuel and manage psi, and the person i spoke with at their store was not any helpful at all, prolly didnt even know what i was asking
