HPT AFR % Error not working
I configured an LM1 to use with HPTuners and the #6 tab Wideband 02 Air/Fuel histogram works great. But when I look at the #7 tab: AFR % ERROR, it is hitting the right cells, but they all say 0
I know my tune is close, but i know its not perfect, as 0 indicates. It should be at least 10 in some cells. Do I have something configured wrong?
Also, what does it use for reference to determine the %error? Does it use the stoich AFR setting in Fuel Control->General? Or does it use the EQ table? Both?
btw this is one a 2bar SD tune.
thanks
thanks
