Could i just use a.....
I was wondering if we are able to use a resistor box inline with the injectors to allow us to run low imp. (2-4) ohm injectors. I am used to doing alot of import cars with big forced inductions setups and to get away with running the low impd. inj. this resistor bank in wired in between the ecu and the inj. on the trigger (negative) wire. Im sure i am overlookin something because this seems all to easy????!!!!!???
i may try it if i dont get many replies.....
Blake
Blake
In theory it is a bad idea because such injectors are designed for a "peak and hold" circuit. But in practice it seems to work as evidenced in the import car culture.
