Calc CylAir vs DynCylAir
I'm using HP tuners, and was going to calibrate my MAF using AFR Error, but my erros is only about +/- 2% at most, and when I plug the MAf in it makes no difference. I have descreened the MAf and put on ported MAF ends.
What I have noticed is my DynCylAir will read 0.80 at WOT at about 5000 RPM
When I plug in the MAF doing the same test, i get 0.72 at WOT at the same RPM when reading the CalcCylAir.
So would appear my MAF is always reading low. Can I calibrate my MAF to the DynCylAir? I guess I could scales the maf to read 0.80 at that test condition... would this be the way to do it?
I dont use LTFT's any more, as I'm running OL all the time. so running leaner at low maps and gets richer as you get towards high MAP.
