Maf + Turbo + HP tuners?
All of the 2-3bar upgrades on HP tuners are listed as SD.
Can you run 2 bar on an '04 ECU with a Maf? I live in San Diego and love to drive from the ocean where I live out to the desert and some times up into the high desert (where there can be snow) all in one day. I dig the idea of keeping my maf.
If I do go SD, can the intake temperature sensor react fast enough to keep a poorly intercooled set up working properly?
the new LS7 computer is a VERY different beast from what we're used to.
the fact that people achieve great results with MAF, doesn't mean they do it right--that's the big difference.
the final formula for fueling (pulse width to be precise) in SD is:
IPW=(VOL* VE * MAP)/(AFR * IFR * R * TEMP)
VOL is cylinder volume
VE is volumetric efficiency
MAP is manifold absolute pressure
AFR is air fuel ratio
IFR is injector flow rate
R is a constant
TEMP is a blend between coolant and intake temps
so as long as your MAP can account for all turbo conditions (aka NOT stock 1bar), and IAT is quick and precise (look on the ls1gto board for omega IAT mod) you should have temperatures and pressures taken into account for.
most aftermarket engine managment systems are speed density, ie. AEM is SD, and there's many 1000rwhp+ supras out there with it. MoTeC can take up to 5bar MAP and is used in just about every real race car out there.
R is a constant
