Idle and accel. help
Its a 98 6spd. T-rex cam pacesetters and duals, Fast 90/90. stock heads.
The car will not start with out me pushing the gas, then it will not stay running. Thats the first problem. The 2nd problem is that while driving the car in a gear if you give it gas it stumbles/chokes, then when you get up above about 4000 rmp's it clears up and runs awsome. What do I need to adjust or where to start. I have hp tuners sofware. Still new at this whole tuning stuff. I would upload the file but the hp tuners is on my laptop witch is dial up and my house is cable. Thanks in advance Shaun
https://ls1tech.com/forums/pcm-diagnostics-tuning/287094-read-me-first-tuning-docs-ve-maf-ses-lights-faqs-more-01-31-07-a.html
Originally Posted by SSpdDmon
You need to start with the stickies at the top of this forum...
https://ls1tech.com/forums/showthread.php?t=287094
To me, it sounds like it's either running rich because he hasn't touched the VE table yet (basic tuning) or he hasn't tweaked the idle spark and/or base running airflow for the IAC (basic idle tuning). Both of those are in the stickies....
Until he provides more detail with a few logs and those procedures have been gone through....nobody is going to be of any help because we don't know what's going on with the car.
To me, it sounds like it's either running rich because he hasn't touched the VE table yet (basic tuning) or he hasn't tweaked the idle spark and/or desired airflow for the IAC (basic idle tuning). Both of those are in the stickies...
