Normal for VE Table to exceed 100%?
Old 12-08-2006, 12:06 AM
Chalky's Avatar
Default Normal for VE Table to exceed 100%?
I added headers and a Balckwing . Went through it and did a VE/MAF tune. Some of the cells were in excess of 100%, (max 107%) @ 4400 and higher map readings.
In comparing my VE table with 2 other VE tables with headers/h/c, I noticed their VE tables topped out around 99%.
Questions is: Is it normal for modified motor to achieve >100% in VE tables?
Old 12-08-2006, 12:39 AM
2002_Z28_Six_Speed's Avatar
I believe that just compares it to a number that you set up. So it would be possible but probably bad practice. The exact thing you are talking about is why I liked how LS1 Edit did their VE. Easier to think in the numbers and units you are actually working in.
Rick@Synergy's Avatar
yes, its normal. VE numbers are only numbers, just put them where they want to be.
Rick
Old 12-08-2006, 12:45 AM
Chalky's Avatar
Rick
Thought so. Just could not .understand why another car with same motor and better cam and heads would have a VE table that topped out at 99%! This was a tuned car as well.
Old 12-08-2006, 08:07 AM
Doc
Doc's Avatar
What is your injector duty cycle looking like? Are your injectors maxed? Or more than 80% ?
Old 12-08-2006, 08:33 AM
LS1TECH Sponsor
foff667's Avatar
FWIW hptuners shows you VE on LS1's in % rather then the raw # just to be more user friendly. Thats why the max % is like 367% if im not mistaken. So yes, perfectly normal to go over 100 ve.
Old 12-08-2006, 09:06 AM
This is because the other guy could have his IFR rate set differently than yours.
Rick
Old 12-08-2006, 09:33 AM
YellowToy/A's Avatar
I think that is to high with just eaders. I never got them that high. Did u disable the MAF while VE tuning??? Did u use a Wideband and monitor your cammanded air flow to wideband???? After u set the PE to A/f u wanted??? If not that is y.
Old 12-08-2006, 09:37 AM
RedWS6 00's Avatar
My VE had some odd curves in it, and exceeding 100 VE, Thats until I sorted my IFR table.
Old 12-08-2006, 09:53 AM
Chalky's Avatar
If I remember, IDC was over 80% but <90%.
Old 12-08-2006, 09:54 AM
Chalky's Avatar
Yes , yes, yes, yes!
Old 12-08-2006, 10:05 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,098 Likes on 721 Posts
A lot faster with the mods Dave?
Old 12-08-2006, 02:19 PM
what was ur wb a/f ratio??? 13.0?
Old 12-08-2006, 03:05 PM
Chalky's Avatar
AFR WB was no richer than 12.6:1 and no leaner than 12.9:1.
FWIW, When I started to do my VE tune, the car went into limp home mode. I added 20% across the VE tables and started dialing it in from that point.
Old 12-08-2006, 03:20 PM
U pass all my tests. It sounds like u did good.
Old 12-08-2006, 03:29 PM
Senior Member
Country Boy's Avatar
Even with my turbo kit, I dont get over 100% VE...
Old 12-08-2006, 03:33 PM
that sure dont sound right. When you are FI, you are more than 100% efficient.
Rick
Old 12-08-2006, 03:34 PM
You know what I forgot to ask, are you still using one bar or two bar? Sorry for that.
Rick
Old 12-08-2006, 03:36 PM
Senior Member
me? 2 bar SD. I also have a BR-FPR that probably scews the numbers too.
Old 12-08-2006, 10:16 PM
Chalky's Avatar
I might find out this Spring John. I was beginning to think I was the only one who had not done a heads/cam.
Quick Reply: Normal for VE Table to exceed 100%?
