250ohm gauge with 90 ohm fuel cell
I got a 2002 silverado , but before you run away because its a "silverado", I believe the fuel gauge is a 250 ohm setup. I recently stuck in a fuel cell with a 90 ohm fuel sender unit. Is there anyway I can wire resistors or use HPTuners to correct the fuel level unit?
thanks.
thanks.
