ASR OFF Light on and off after cam install
Old 12-09-2006, 02:42 PM
2002LS1Z's Avatar
Default ASR OFF Light on and off after cam install
Just picked up my car yesterday after getting a cam installed. Now I realize that putting the car on the dyno will make the light come on and then it normally goes off after a few miles. Now the ASR off light randomly comes on. What could be the cause of this?
Old 12-09-2006, 02:55 PM
RZRSEDGE's Avatar
Have you had it tuned? Mine even after a tune tends to do it sometimes. Does'nt bother me much but I'm gonna work on it. I was told a while back on here that this can be taken care of through a proper tune. Good luck!
Old 12-09-2006, 03:01 PM
2002LS1Z's Avatar
Yes it's been tuned.
Old 12-09-2006, 09:23 PM
Doc
Doc's Avatar
You might actually have abs wheel sensor going bad (totally unrelated to the camswap).
Old 12-10-2006, 01:33 AM
2002LS1Z's Avatar
Even when just idling?
Old 12-10-2006, 06:29 AM
RZRSEDGE's Avatar
Sorry, didn't see the "tune." But as I said mine has a tune and still does it to.
Old 12-10-2006, 10:36 AM
2xLS1's Avatar
Your P0121 error min and max map values are set wrong in your tune.
Old 12-10-2006, 11:56 AM
Restricted User
98Z28CobraKiller's Avatar
If you have different sized (diameter) tires in the front to the back, it will cause this problem as well as the ABS Inop.
Old 01-08-2007, 05:15 PM
2000WS6Vert's Avatar
This is happening to me now too! Just swapped the cam this weekend and now this same p0121 code is popping up.
Old 01-09-2007, 09:27 AM
V6 Bird's Avatar
Negative, its a problem with vaccum sensing at the map sensor. If the parameters have not been changed there to make that light go on and off it needs to be.
V6 Bird's Avatar
Thats correct!!!
Old 01-09-2007, 09:47 AM
Doc
Doc's Avatar
And the correct settings are?
Old 01-09-2007, 11:03 AM
HumpinSS's Avatar
They are just diagniostic test so setting them so the light doesnt turn on will do no harm. Usually 0 for the first few columns should do it
Old 01-27-2007, 11:12 AM
2002LS1Z's Avatar
I had my car retuned again, the min and max values were changed again. I still get this light. Looks like i'm just see if I can disconnect the bulb.
Quick Reply: ASR OFF Light on and off after cam install
