big stuff 3 a good choice?
ok well i am setting up a twin gt35r turbo system to be run with a 427 ls1 in my 1991 Z. now im getting everything together and have yet to get a PCM and harness....i plan to first get the engine in and all set and then start working on the turbo system all while i will be driving the car by hopefully this summer (non turbo). my goals with the turbo system are to break the 1000HP mark and seeing as i would like to do everything once the correct way, should i just go ahead and get a Big Stuff 3 kit to run my motor? will this work fine on the motor while it is N/A? ive read SD is good for when in high boost and when the maf is maxed out but will it work fine on just the motor for the time being?
i have all aftermarket auometer guages that i bought to work with the whole lsx set up but they are aftermarket...? will these work fine or do i need some other guages? cause if thats the case then screw big stuff cause ive spent near $1000 on just damn guages...
