Anyone have a write up on removing engine harness
Looking for some help i'm going to be chaning my engine harness.Just seeing if someone had write up or some detailed info to help me out
Thanx,BTLFEDSS
Thanx,BTLFEDSS
It's actually pretty easy. 1) Disconnect battery, 2) disconnect and remove the PCM, then 3) disconnect all of the engine sensors, and 4) disconnect the 2 white connectors inside the interior located on the passenger side under the dash. You need to remove the kick panel to access the connectors and pull them through the firewall to the engine bay.
