98 to 99+ pcm
Old 12-27-2006, 10:10 PM
Honda Hunter's Avatar
Default 98 to 99+ pcm
Can you swap pcms to do this? If so is it as easy as swapping the ecms and if you cant do it why not.
Old 12-27-2006, 10:41 PM
gametech's Avatar
There are several threads on why this won't work without a lot of rewiring or possibly changing the entire instrument cluster. GM screwed the '98 buyers.
Old 12-27-2006, 10:51 PM
Doc
Doc's Avatar
I was in Bahrain early this year on business, too bad we didn't meet up. The swap is not impossible but well worth it if you have any future Forced Induction/ NO2 plans. After the swap you can run EFI Live's Custom Operating Systems that will support big power and drivability.
Old 12-28-2006, 12:10 AM
I need to swap my instrument cluster anyways so that's not a issue. If that's the biggest issue then I'm cool but Ill try a search also. I just didnt know how to word the search.
Any time youre back in Bahrain let me know. Ill be around for at least another year.
Old 12-28-2006, 03:08 AM
ringram's Avatar
PM Doc he can probably help you out with info on the pin swaps.
Old 12-28-2006, 03:59 AM
I did a search (what I shouldve did to begin with) and I now see this isnt as simple as I thought. The only reasons I wanted to do it was so I could purchase a handheld tuner but now I'm told SCT makes one for the 98's so all I really need now is to get my hands on a 98 cluster and I'll be in like Flynt.
