Gm 3800 driveability issue
Old 12-31-2006, 01:27 PM
toneloc60's Avatar
Default Gm 3800 driveability issue
I'm trying to play over the phone auto doctor for a friend of mine. He's working on an '02 Regal with a 3800. The car idles fine, but at 2000 rpm it starts pinging. The knock sensors are picking up the ping, then pulls timing. It pulls a total of 12 degrees.
The engine wont rev over 2500 rpm, and the car can not build speed over 25 mph. The computer is picking up misfires on all cylinders, but cylinders 2 and 6 are registering the most.
Thinking it may be injector problems, he swapped 2 and 6 for 1 and 3 but noticed no change.
He and I have started to suspect the problem may be in either in the fuel filter, or even in the fuel itself. I've told him to call the gas station the owner of the car last filled at and change the fuel filter. He's also going to fill a small clear jar with fuel from the inlet line from the fuel filter to check the fuel for any noticeable contaminates.
On a call back to the car owner, she had even questioned whether it could be a problem from someone tampering with her fuel. So, I think we may be on the right track.
I'm hoping someone here may be able to come up with some ideas on this in case we're off base.
Old 01-01-2007, 04:14 AM
usd2sing's Avatar
sending PM
