How bad without a tune?
Old 01-09-2007, 11:13 AM
crazylane's Avatar
Default How bad without a tune?
I plan doing a head and cam swap at the beginning of feb, The cam is 233/239 112lsa from TSP The heads are 5.3 stage 1.5. and I might not beable to get it to the tuner until the middle of the month. It is an A4, I am putting in a 3600 stall also. But what my question is. If I drive it like that without a tune for two to three weeks, will it damage anything or will it just be really shitting drivability?
What can be expected of driving it without the tune right away?
Lane
Old 01-09-2007, 11:21 AM
LS1TECH Sponsor
foff667's Avatar
HORRIBLE, I had the TSP 231/237 cam in my 98Z with a tci 3500 stall & without tuning it would stall at just about every stoplight. Also wouldnt go into 1st or 2nd gear at WOT.
Old 01-09-2007, 06:24 PM
crazylane's Avatar
Anybody else???
Old 01-09-2007, 06:34 PM
brad8266's Avatar
It will run like **** when you can actually keep it running. get the tune before hitting the streets with it.
Old 01-16-2007, 02:53 PM
TheLS1Kid's Avatar
i have a TSP 233/239 with a tune. if i dont let the temp gauge get a little past 100* on a cold start it will stall. my tune is for a smaller cam that was put in and then taken out for the 233/239. after it warms up it runs perfect and idles at 750rpm. oh yea this is with an m6 so an a4 would be even worse. it just needs a little tune and it should run fine. but heads up on the shitty drivability with no tune and an a4.
Old 01-16-2007, 02:55 PM
2000WS6Vert's Avatar
Get that puppy tuned immediately!! If you have HPT/LS1edit etc start doing research on what parms you have to change to keep it running. If not....get it tuned ASAP.
Just did head/cam swap to a much milder setup and even after changing stuff in HPT I could barely keep it running.
Good luck!
Old 01-16-2007, 03:06 PM
Fratsit's Avatar
Like others have said, it will want to stall at lights, ect. The sooner you can get her tuned the better.
If you need some help with the swap I will be more than happy to lend a hand.
R/
Jeff
Old 01-16-2007, 03:36 PM
sidewayz28's Avatar
i drove my 232/234 .595/.598 about a month w/out a tune. the tune helped a ton! after putting on untouched 243 heads & a 90/90 it needs a tune again, but im guna man up and wait about 2-3 months until i get it dyno tuned again so i can tune with direct port
Old 01-22-2007, 02:32 PM
Gingervitis Addict
slow67's Avatar
I drove my Trex for about a month without a tune....just kinda rich...
