tuning solutions for 98 pcms over 15psi...
Old 01-09-2007, 04:16 PM
obZidian's Avatar
Default tuning solutions for 98 pcms over 15psi...
Just interersted in seeing what the general populus feels or has done with a 98 pcm nd tuning over 15psi (2bar)
Hptuners has the 2bar setup right now but its restrictive in the amount of boost im interested in.
Anyone here venture into a 99+pcm swap or using tuning tricks to get the 98 pcm to handle the extra boost. Magnus mentioned that i could use the 2bar and have a constant level of fuel for anything above or equal to 15psi or 2bar.
thanks!
Old 01-09-2007, 04:33 PM
frcefed98's Avatar
Kyle is successfully running MAFT PRO on his ride, past 2 bar, stock 98 PCM.
Harlan set it all up for him, I guess it works pretty damn well.
J
Old 01-09-2007, 04:53 PM
B18CYA's Avatar
how bout you forcefed what are you using?
oh i see you are sd, so since you are not using your maf it dosent matter
Old 01-09-2007, 04:56 PM
SuperZ's Avatar
Im interested in this also.Im running 14psi threw my mass air with ls1edit tune.It is working great.Im sure I could be making more though
Old 01-09-2007, 05:02 PM
B18CYA's Avatar
I think your going to see better gas mileage with you maf though.
hows is your mileage now?
Old 01-09-2007, 06:17 PM
frcefed98's Avatar
Haven't pushed my car past its 2 bar limit. If I do plan on pushing more than 15psi I will be going with the MAFT pro as I know it works.
J
Old 01-09-2007, 10:58 PM
obZidian's Avatar
i went to the mafpro site and read through it...
but im a bit lost still on it. How exactly would we implement this into our pcm? I beleive kyle just uses it for fuel, right?
Old 01-09-2007, 10:59 PM
FormulaFire's Avatar
Big Stuff 3
Old 01-09-2007, 11:04 PM
MECHAM's Avatar
kyle had harlan set it up on his car...and from what was posted here..it work daym well.
now...for the rest of us getting our hands on what harlan did...
