Injectors.xls file
It's in the sticky...
http://www.allmod.net/hpt/injectors.xls
You just have to click on the EFI Live tab at the bottom.
Also, check out the conversions tab on the main window when you open the tuning program. It can turn most any table sideways. So, if you have something going left to right and you need it to go top to bottom, it'll get 'r done.
Originally Posted by 2xLS1
Thanks, I already had a version like that and completely missed seeing the tabs at the bottom. I know there was a version floating around once that had the vertical data below the tools section without tabs. In fact the one version I have with the tabs has a couple more conversions in the tools section than the one you linked to.
