shift points
Old 03-29-2007, 07:30 AM
BOTTLE ROCKET's Avatar
Default shift points
How difficult is it to set part throttle shift points and WOT downshift points with HPtuner? Is it very complicated/time consuming?
Old 03-29-2007, 08:38 AM
12secSS's Avatar
It can be. It is very user specific. Some drivers may like the current shift points, others may prefer a delayed shift points ... not an easy one fits all scenario. The tables are MPH based, just primarly log: TPS%, MPH, Engine RPM, Trans Current Gear and TCC Mode ... this should help you fine tune the shift points you desire.
Old 03-29-2007, 08:47 AM
Is there a screen that you will go to that will allow you to put in a mph # for either the shift point or down shift (for each gear of course), or is it more complicated than that?
Old 03-29-2007, 10:08 AM
12secSS's Avatar
There is a Automatic Tab, which holds the shift tables (based on MPH vs TPS) and lock up points (based on MPH vs. TPS).
