HP Tuners 2Bar SD Tuning
Old 04-01-2007, 11:13 AM
1INSANEGTO's Avatar
Default HP Tuners 2Bar SD Tuning
Ok found out from other SD owners I might be running the incorrect map sensor.
But how ever that does explain why the car was such a pain in the *** to even get to start. My tuner is very very well known with Hptuners and even he is lost.. Till we found out about the map sensor.
So with that said I am going to post a file we created. It might be off because we tried everything to even get the car to start.
Can someone give me so tips on what might need to be changed back?
BTW knew ECM corrected the upload speed we had a issue before with.
I will be ordering the correct sensor monday
File Type: hpt
Old 04-01-2007, 01:00 PM
1INSANEGTO's Avatar
Ttt.......
Old 04-01-2007, 01:33 PM
code4's Avatar
The sensor I used is gm part # 12580698. I ordered it through gm parts direct.com It has worked perfectly.
I'm not flaming your tuner but if he is well known, he should have a ton of bin files to compare.
I looked at your tune & there are a ton of differences from mine but I don't know if it is because yours is a GTO. I'm not a qualified to help much as I'm a total newb to tuning but mine is up and running pretty good. GL
Old 04-01-2007, 02:11 PM
2xLS1's Avatar
http://www.hptuners.com/forum/showpo...72&postcount=3
