code help p1336
Old 04-01-2007, 09:59 PM
brads01ws6's Avatar
Default code help p1336
this code popped up after my tr224, ported heads, sts turbo.. i already had lt's before the other parts. my scanner says manufacture control. ignition system or misfire i know gm's listing reads different than that, i just want to know if anyone else has encountered this problem and does anyone know how to fix it.
i tried to search this code but the site wasnt working so if someone can direct me to some helpful info i would be greatful. thanks.
Old 04-01-2007, 10:05 PM
ChrisS@sdpc's Avatar
Hopefully you have access to a tuner/scanner that can perform the Crank Position Relearn function. That is likely your problem. More detail here.
