Oil light problem.. anyone have an idea?
Old 04-05-2007, 10:26 AM
RollinSScamaro's Avatar
Default Oil light problem.. anyone have an idea?
Well i am having an oil light problem in my camaro.. the problem was the positive side of the oil level sensor got ripped out and was out for a little while... but when it was put back in it still stayed on.. the voltage was tested on the wire and i guess its supposed to have 12V and only had 4V? Did i short out that whole circuit or wire in the harness?
what should i do to fix it? pull the bulb out and ignore it? or try to run a 12V source to the wires?
If anyone has some simple ideas for it.. let me know! Thanks guys
Old 04-09-2007, 12:01 AM
ttt... anyone?
Old 04-11-2007, 11:25 AM
i guess i'll try one more time... ttt.. i'm pretty much lost on how to fix it.. seems like the wires grounded out and shorted the circuit maybe? i'm not too sure.. any help would be greatly appreciated
Old 04-11-2007, 01:03 PM
2001NBMZ28's Avatar
Did you replace the sensor? Helms says to check circuit with a scan tool first, then pull the C1 PCM connector and probe the signal circuit of the oil level switch to B+, test switch ground circuit at the connector for open or high resistance, etc. Have you been driving the car? After the light comes on it won't go off until the PCM sees 194* ECT and the ignition is turned off for a minimum of one hour, then rechecks on the next cycle. If you haven't replaced the sensor I'd do that first if there isn't an obvious wiring/connector problem near the sensor. Hope this helps...
Old 04-11-2007, 01:20 PM
2001NBMZ28's Avatar
Just in case you need it, the latest PN I have is 12603782 - just over $20 GM list. Doublecheck before buying, PN keeps changing.
Old 04-13-2007, 10:18 PM
thanks! i'll check into it! i'll let ya know what happens once i try a few things! Thanks a lot i appreciate the response!
