'99 Corvette FRC stock HPTuner scan
Old 04-06-2007, 08:06 PM
Chevy406's Avatar
Default '99 Corvette FRC stock HPTuner scan
If someone feels bored and wants to browse through this scan of my stock '99 C5, I would appreciate any feedback. Do you see any gains available from the tune... The drivetrain is absolutely stock - for now.
File Type: hpl
Old 04-07-2007, 10:14 AM
txhorns281's Avatar
attachment not downloading for me, but usually from stock form there's a couple horses to be had
Old 04-08-2007, 08:30 AM
2MuchRiceMakesMeSick's Avatar
it works for me, you just have to right click and save as then rename the extension to hpl
it looks you need to cut the timing a little bit because your getting too much kr
Old 04-08-2007, 02:53 PM
txhorns281's Avatar
Looks like it was only in 1st gear, but definitely some nasty KR flare up. Possibly TQ mgmt engaging along with TCS, WOT looks to be a bit rich, probably free up some horses by leaning out a tad. Wideband data would be more useful but going by O2s and trimming, looks a little bit rich.
Old 04-09-2007, 10:54 PM
Chevy406's Avatar
I appreciate the comments. Unfortunately I forgot to turn off traction control, so after feeling it engage I backed off the throttle, turned it off, and got back on it. I don't know if that is what kicked in the knock or just too much timing. Also note that the intake air temp. was 109 degrees.
I am a little old school, this being the first LS1 I have had. I am suprised by the small amount of timing advance that the LS1 requires. Is it common to be in the low 20s at wide open throttle? I would expect mid 30s in a first gen SBC.
Clyde
Old 04-09-2007, 11:56 PM
2xLS1's Avatar
LS1 cylinder head design requires way less timing than the old school sbc motors. Low 20s is a little low though. Most like somewhere between 26~30.
