help diagnosing P0332
I went to fire her up this morning and i got a check engine light P0332 ( knock sensor bank 2 low input) I Haven't been giving her hell lately. Does anybody know what i should troubleshoot, or what the nature of the problem is.Thank you.
Mods are long tubes, exhaust,airlid and slp maf (got tuned with the car)
I am not sure what kind of car that you have, but I see that you have an LS6 intake, was that a recent install? I would have to say that it is a Knock senor or the harness is shorted/damaged between the sensor and the PCM. I think you can unplug the senor harness to ohm the sensor behind the intake it needs to fall between 93-107Kohms that might save you removing the intake if they test good.
