drive shaft speed sensor with EFIlive
Old 04-12-2007, 04:50 PM
7 Second Club
ty_ty13's Avatar
Default drive shaft speed sensor with EFIlive
im looking for a way to monitor DS speed with a aftermarket sensor... im not sure how to do this but i think you would be able to...
i want to be able to look at engine rpm Vs. DS rpm for converter efficiency.
Old 04-12-2007, 04:51 PM
7 Second Club
ty_ty13's Avatar
and no my speedo doesnt work on the back wheels.... and no the front wont work because my wheels should be off the ground for a good 50ft.
Old 04-12-2007, 04:55 PM
7 Second Club
ty_ty13's Avatar
im wondering if any of these would be a good start
http://www.racepak.com/F3-D5.html
Old 04-12-2007, 09:24 PM
Brent@LPE's Avatar
...and monitor in EFI live ?
maybe converting a wheel speed sensor is the way to go?
The sensor is ready to go.I imagine you could use a reluctor wheel on the yoke (Moser makes them in billet steel ) you would then need to convert say left front wheel speed in MPH to RPM. and then in the 1:1 gear you should be able to calculate convertor slip....
I will have to think about this some more.I think I have a Moser reluctor wheel at the shop I will measure it in the morning
Old 04-13-2007, 07:50 AM
7 Second Club
ty_ty13's Avatar
im also wanting to see a graph of the engine and DS through the whole run not just a converter slip at the far end... im also concerned with the way the converter opperates during the 60ft...
Old 04-13-2007, 08:15 AM
Old Geezer's Avatar
We used a Datamite setup. You epoxy a small magnet on the DS, and fab a brkt to hold the pickup. I'll have to look to see what the signal voltage is....
Brent@LPE's Avatar
On the manual gear box's we had a sensor on the trans input shaft that is where you will need to pick up for slip.If you pick it up there you will see the correct engine to trans input ratio for every gear.I dont know if I have ever seen one in a automatic.The Comp/Elim racepack graphs for automatics that I have seen they where just D/S rpm not trans input. I imagine a hole drilled into the input shaft to accept a magnet and a place for the sensor will get you there, packaging will be a issue. Also how to get a PID in EFI live to register it as RPM. Unless you are in the plans of some other sort of data recoder???
Old 04-16-2007, 11:05 AM
blandmiller's Avatar
Why can't you use the GM.TOS (transmission output shaft) value? This is the method I commonly use to indicate TCC slip.
Old 04-17-2007, 07:10 AM
P Mack's Avatar
Why doesn't your speedo work?
Old 04-17-2007, 03:57 PM
7 Second Club
ty_ty13's Avatar
th350 tranny and 12bolt rear...
Quick Reply: drive shaft speed sensor with EFIlive
