have some o2 raeding questions
Whats the differance between o2 millavolts vs. wideband readings? Reason i ask is because i see people using the gauge that tells you the millivolts and retard in one box. Or they use a wideband. Cant you tell your a/f with what millivolts the o2's are showing? Mine are between 940-960 at WOT. Bare with me guys as im just getting into this tuning part of it all.
This is on my '94 lt1 car also. But id assume a o2 is a o2.
LS1Tech Sponsor
the stock narrrowband O2 sensors aren't accurate at the WOT/PE levels, only at stoich 14.7 for normal cruise/driving.
But, if a wideband is not available, you can adjust your WOT/PE fueling to a "safe" range by getting the stock NB O2 sensors to read in the .88xx to .92xx range.
.940 to .960 sounds like you're probably running a little rich(er) than you need to at WOT.
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
