Will a 98 PCM Work In a 99?
if it's an 00 it should fire.. but it may require a CASE Learn in order to fire up consistently (99 and 00 Operating systems are pretty similar... even all the way down to the injectors)
Same transmission type?
what if you give it a little gas while cranking? check the fuses under the hood just in case
I gave it a little gas while cranking and then I checked and was getting no fire. I thought it may be just vin locked or something. When I would stop turning the motor the gauges would go up and down. Both cars are m6s. What fuses should I check out? I had swapped pcms on lt1s before and they always worked. I guess ls1s are more complex.
