Car acting funny after new clutch?????
Old 04-29-2007, 12:02 AM
orangeirocz28's Avatar
Default Car acting funny after new clutch?????
Bought my car last july and has run great since then til now. The clutch went out, so I installed a SPEC 3 clutch with a lightened flywheel. Since the install, the car will crank fine, and even idle normal, but in light excelleration you can feel it buck slightly, and its like its in and out as far as power, but still driveable. Also when driving, and depressing the clutch when comming to an intersection or stop, the RPMs drop to like 400 or 500 RPMs or it will stick at like 12 or 1500 for a couple of seconds, and even cuts off a lot also. There is no check engine light on, and I pulled the fuses and let it sit with the key on for 5 minutes, and all, and that didnt help. Also something weird is sometimes the gas gauge will drop past empty every once in a while at random when the car starts acting up. Anyone had this problem after a clutch install, or could it just be coincidence that something else went out randomly? Any help would be great.
Thanks
