Crane Cams Tuner?
Crane Cams Tuner?
Used a couple of times on my 02 T/A. Returned PCM to stock tune, then had LT's installed and dyno tuned with LS1 Edit. Can I still use the Crane tuner for reading and clearing codes ONLY, or will it mess up the PCM if I connect it? Thanks for your help.
Don't see why not - should be able to tell you when plugging it in? I use my Predator to read/clear codes and see real time data all the time on other cars - I just select diagnostics or real time data.
Just using it as a scanner shouldn't make you upload the tune, should ask you if the car is an A4 or M6 though. Never used the vinci/crane handheld - someone will chime in. Don't upload/mess with your modified tune.
Originally Posted by sunsetta
Even if you use the diagnostic portion, doesn't it load the tune into it first? If so, will it be able to load the modified LS1 Edit tune?
