Eliminating Rear O2 Sesors Through Diablo Programer
Old 05-06-2007, 07:14 PM
Restricted User
Zero4488's Avatar
Default Eliminating Rear O2 Sesors Through Diablo Programer
On my diablo programer it gives me an options to remove the DTC for my rear o2 sensors...but today the code came back...any ideas?
Old 05-06-2007, 07:41 PM
2001NBMZ28's Avatar
I don't have the updated unit that lets you delete them permanently - If you have to delete them individually sure you got them all? There's a bunch...thinking P0420, P0430, P137, P0138, P0140, P0141, P0157, P0158, P0160, P0161.
Old 05-06-2007, 07:45 PM
Restricted User
Zero4488's Avatar
I'm positive I went through everyone....I'll double check though....but besides that...any ideas?
Old 05-06-2007, 07:58 PM
2001NBMZ28's Avatar
Just scan the car and permanently delete the rear 02 code that showed up.
Old 05-07-2007, 03:43 PM
Restricted User
Zero4488's Avatar
Well I deleted it...I just hope it doesn't decide to come back...
Old 05-07-2007, 07:07 PM
sprayjunkie's Avatar
What codes were coming up?
Once they are disabled, they should not return.
You may have a malfunctioning O2 sensor causing the code...have you had any exhaust work done recently?
Old 05-07-2007, 08:39 PM
Restricted User
Zero4488's Avatar
Not since the SLP headers and exhaust...and that was a few months ago already...
Old 05-08-2007, 08:30 AM
If the code comes back, look it up and make sure it is not the result of a malfunctioning O2 sensor.
Old 05-08-2007, 09:58 AM
Restricted User
Zero4488's Avatar
I'll remember to check that if it comes back...
Old 05-11-2010, 10:12 AM
chuckrock's Avatar
I dont have a Diablo Tuner yet and the guy at Diablo was really unhelpful all he tried to do was sell me to LEW. If I bought the Diablo Tuner can I delete the REAR O2 Codes and the MAF on my own? Or do I need to log stuff and send it to someone. I have never used a Hand Held Tuner before so this is all sketchy to me. I have an stock 04 GTO with LT Headers, CAI on the way as well as wanting to do the O2 Delete, and MAF Delete but I would like to do it myself instead of paying someone.
-Charlie
Old 05-11-2010, 03:39 PM
LS1Tech Sponsor
06MonteSS's Avatar
are you just deleting/erasing/clearing the trouble codes??? or actually "disabling" them... if you're just clearing them, they will come back...
and, do you have one of the older version predators that still let you actually "disable" the codes?? it would be on a 2.xx revision...
because the newer ones do not let you disable the codes... that functionality was removed due to EPA regulations...
if you're predator is on a 9rXX revision number, it is one of the newer ones, and in that case you'd need to get a custom tune created in order to have the codes disabled so they don't come back.
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old 05-11-2010, 03:40 PM
LS1Tech Sponsor
06MonteSS's Avatar
-Charlie
Charlie...
you and I have been emailing back and forth all day, and all of your questions have been answered, and everything explained out to ya...
__________________
Quick Reply: Eliminating Rear O2 Sesors Through Diablo Programer
