Pedal voltage Vs Pedal position
I have a problem that the pedal postion is not alway zero with no weight on the pedal. The pedal voltage was .46 with the engine off. Once the engine started the voltage when to .51 and the % read 1%. I then moved the pot so that the voltage .41 with no pedal. The Pedal % was 0 with the engine off. Once I started the engine pedal voltage when to .46 and the pedal read 1%. It looks to me like the pedal % changes to match the low voltage any time the car is started.
Does any know how the pedal handling work? What can I do to change the voltage to % vs voltage?
You may need to recalibrate the TPS sensor. This can be done by disconnecting the TPS sensor connector. Then turn on the ignition, not the car. Verify the TPS fault code is thrown. Turn the car off, and reconnect the TPS connector. Turn the ignition on, not the car. This may solve your issue, it has worked for me a couple of times. Also verify that the throttle cable has some slack, and is not under tension. This can affect your TPS reading/position as well. Good luck!
Yes GM knows that the electrical tolerances vary from TPS to TPS so the PCM learns what voltage is closed throttle and what voltage is WOT. When applying the brakes and upon startup the PCM knows that you shouldn't be applying the throttle so it takes this voltage whether it is .46v or .51v and associates it with a closed throttle reading. A couple of wide open throttle runs on the highway and your PCM associates the highest voltage as being WOT. So make sure none of your accelerator linkage is binding and you should be fine unless you throw a code.
