1st Log with EFI Live; why no KR logged?
Just got FlashScan, did about a 15 minute drive. Opening the log, it shows 0 KR anywhere which, while would be nice, can't be right. I Used the default Imperial PID set in EFI Live and it did record many things (aside from IAT temp and RPM, all of which i have yet to learn what they are) but the 0 KR everywhere is puzzling and a bit scary. Did I just log something wrong or is it possible our tuner turned off knock sensors and that is the reason? That would kinda suck..
Anyway, the log file is attached...if someone could look at it for alarming things, that would be cool. Also attached is our HP Tuners file as well, if that would help.
Also, I don't suppose there is any way to view our .hpt file in EFI Live, is there?
Anyway, thanks for any help anyone can provide. This initial foray into EFI Live makes me feel like I'm back in college taking Calculus...
In The EFI Lives scanner I picked the Description "Retard due to Knock" PID or the parameter "GM.KR". When you drive around logging It's normal to get Zero KR most of the time. BTW, The first week seems a little overwhelming at first but in no time you will wonder why You ever thought you had a problem learning EFI Live tuning/scan tool. I think It's way easy now.
