boost & fuel pressure gauge install
I am trying to locate a place on the rails to hook the fuel sender up to.
I have an LS6 intake and located the schrader valve but it doesn't look like it can be removed from the rails.
Do I need custom rails?
What are the adapters I need?
As for the boost, I have the 1/4" nylon tube and "T" but haven't located a place for it. My vaccuum line are all 3/8". Is there an adapter or a better place to tie this in as well?
Thanks
Thanks
You need to remove the schrader valve with a valve stem removal tool. The threads for the cap is 4an, so you'll need a 4an female to 1/8 npt female (most gauges use 1/8 npt male fitting).
