Dialing in MAF
Dialing in MAF
Would someone be so kind to dumb this down for me. I had my tune fairly decent in OLSD. I just went back to CL MAF and need to dial this MAF in. I did search and found this....
"After this, it is time to tune MAF/WOT. Reset the MAF fail back to 14000 (leave everything else as is for now) and modify the MAF Calibration/Airflow vs. Frequency tables the same way you did for the VE tables, except you will use MAF vs Output Freq (Hz) histograms instead of the VE histograms. The MAF Calibration table is just above the VE table(s) on the same page in Editor.
After tuning MAF/WOT, set all of the above tables back normal and you’re done. Time to move on to spark, transmission settings or whatever you decide to do next."
I cant seem to find the "MAF Calibration table" or the MAF vs Output Freq histogram. Where are these, and how would I go about tuning them?
TIA
TIA
