View Poll Results: Tuning Options
convert to 99-02 PCM and use 1 BAR SD
1
50.00%
use stock 97-98 PCM w/ 2-3 SD & Map Sensor
0
0%
use stock PCM, ditch the 75mm MAF and use GM 85mm MAF
0
0%
use stock PCM w/ 75mm MAF will be enough to produce 500WHP N/A
1
50.00%
Voters: 2. You may not vote on this poll
Tuning Option for 97 Vette
I own a 97 vette, currently stock, but im gonna replace it with a 408ci motor and a 200 Shot Progressive Nitrous system.. my goal is 500whp N/A and 700whp with NOS.
Just wanted your thought on what tuning method/option to use
P. S. my goal is a low 10, high 9's street/strip daily driver.
thanks & appreciate your replies
Originally Posted by Magnus
CamaroZach's 98 twin turbo vette was tuned to 700rwhp with our 2bar solution on the 97/98 PCM.
I read in HPT website that 2-3BAR SD is for boost applications.. so can it be used for N/A? cause i dont have the option for 1 bard SD unless if i upgrade to a 99-02 PCM.
I am currently in the planning/ parts acquisition stage on a 97 vette and 98 Camaro, both with similar goals. I voted for the upgrade. EFI Live's custom OS's are free with free updates for life. Custom OS #5 sounds like a great fit for your application. Change tunes from NA to N20 at the flip of a switch. I was in Bahrain on business last year in May. I might get a chance to take another trip this year.
Doc, im using HPTuners, how much power would i yield swithing to a newer PCM?
Magnus, would i require a 2 BAR map sensor or should i use the stock one?
thanks
thanks
