2004 C5 Z06 427 - Flashing A/C light
Old 06-02-2007, 08:52 AM
Billiumss's Avatar
Question 2004 C5 Z06 427 - Flashing A/C light
I'm working on a 2004 C5 Z06 that has a 427 in it. So far everything is going good. Fueling is good, idles good, etc...
When your at idle and you turn the A/C on, the A/C clicks on and off. You can here it and also see the light on the A/C button go on and off as well.
When your going down the road or have the RPMs a tad higher than idle, the A/C stays on all the time like it should.
What would cause this to happen?
It has a 240 116lsa cam and at idle it's about 51-53kpa
Old 06-02-2007, 09:25 AM
muncie21's Avatar
low pressure safety cut off??
Old 06-02-2007, 12:56 PM
P Mack's Avatar
It could be the stall saver if you have that enabled. If it goes into "stall saver" mode, it disengages the ac clutch.
Old 06-05-2007, 08:20 AM
Billiumss's Avatar
Arrow
I found the problem, it ended up being that the Stall Saver was "Turned On", it had values in the 2 tables. A pro shop in Michigan tweaked the car at one time and put values in.
Thanks for the tip!
