PLX SM-AFR/DB-5 problem................
Hi,
I just got my SM-AFR/DM-5 combo and I started to hook it up. I had gotten the sensor installed in a separate bung in my exhaust and that part went pretty smoothly.
Then I ran the power into a switched separate circuit, and ran the ground back to the battery (I used a battery tap post that I have for my stereo stuff).
Now, here's the problem, When I switch the car on, the gauge does nothing for a few seconds and then it makes what looks like two sevens in the far right and next to the far right LED spots/post, then when that stops, it makes an r in the first LED post/slot. Can someone Please tell me what's going on?
I'm pulling what's left of my hair out!
Thank You in advance!
By the way, it's also plugged into the TX terminal
