SD tune for a street car......or keep the MAF
First off all, does anyone make a 105mm MAF?
I want to use a 105mm TB with the sheet metal intake.
But if a SD tune will work perfectly for a street driven car with no issues I'll just do that and there's nothing more to look into.
If not, I need a 105 MAF.
Originally Posted by Frost
You CAN run SD on a 98, the PCM is just kinda lacking compared to later years in lots of areas.
If I remove my MAF Sensor it's going to set a DTC (which I can permentaly ignore), I can then use the Main VE tables (both Primary and Secondary) to control my fuel trims rather than it using the MAF Sensor? This will allow me to breath in more air, in turn allowing me to be able to add more fuel, correct?
Originally Posted by Rebel_Bowtie
Sorry, I'm just getting started tuning using HPTuners and have been reading several docs but I'm still getting everything figured out so I want to be clear....
Not really.... The MAF isn't a proven restriction until the 500+ hp range. Also, without a custom OS you will be limited to the low resolution of the secondary table. If you are just getting started, stick with your MAF.
Buy and use a wideband; don't tune without one
It seems that a SD tune would make more sense in some areas, but in other areas it may be more of a pain in the ***.
In FL where I wnt to school the weather year round only swings in temperature around 30-40 degrees at the most
where as in New England where I am from the temperature swings in temp around 100 degrees and can change in temp from one day to another 20 degrees easily.. I would think this would wreak havoc on a street driven SD tuned car.
Where is this 105 at? Is it for the ls1? All I can seem to find is a 105 for the mustang on accufab's site. I also cannot find the 100mm tb on lingenfelters site. Anyone know if you can port out a fast 90 for one of these things?
LS1Tech Sponsor
Not at all if you know what to do.I've probly got 4-5 2 bar SD cars/trucks out there with 750+rwhp running great.The temp changes do not change the tunes.
Hey thats good news. I would deff listen to slowhawk he knows WAY more than myself
Me = noob
him = veteran
Btw slowhawk I wanted to talk to you at some point about which setup I should go with on my Ls1/rx7. I am in mass on the cape and I heard you were the guy to talk to.
