(EFILive) Im wanting to lower fans temps
Old 06-10-2007, 05:56 PM
SpdFrk1990's Avatar
Default (EFILive) Im wanting to lower fans temps
I got a stock t-stat and my mods are in my sig. What would be some good temps to change my fans too. I know 210 is normal but I want her a little cooler. here is a screen shot of the stock fan temps.
Old 06-10-2007, 08:02 PM
SpdFrk1990's Avatar
Any1 I was going to change this in a few hrs when I get home from work.
Old 06-10-2007, 08:12 PM
SSpdDmon's Avatar
When I had my stock stat in my last Z, I believe I just dropped the temps 20*F from stock.
Old 06-10-2007, 08:33 PM
SpdFrk1990's Avatar
Thanks man I think I might get a 160 stat this week also.
Old 06-10-2007, 08:39 PM
SpdFrk1990's Avatar
K temps are lowered 20deg just have to flash it when I get home.
Old 06-10-2007, 11:50 PM
Shallow Bay's Avatar
I also lowered my fan turn-on temps right around 20*F from stock.
Attached Thumbnails (EFILive) Im wanting to lower fans temps-fan-settings.jpg
Old 06-11-2007, 01:55 AM
SpdFrk1990's Avatar
Lowered mine down about 10 more degrees to 191 kick on temp hopefully she will stay around 190ish now.
Old 06-11-2007, 02:31 PM
SpdFrk1990's Avatar
The extra 10 degrees didnt help still will run right around 200 so I raised them back up 10 degrees. They are lowered about 25 degrees from stock.
Old 06-11-2007, 09:06 PM
PICNIC_GEORGE's Avatar
Remeber your gauge is a dummy gauge it really won't change. You're gonna have to use the scan tool to see what it really is. But with a stock thermostat it will probably stay around 200* anyways.
Old 06-11-2007, 09:57 PM
SpdFrk1990's Avatar
I was logging with efilive. I agree u cant get it to stay much under 198 or so with the stock t-stat.
