NOOB Ques on PCM location
I'm installing a Shift Light into my stock 2001 Camaro Z28 and I don't know where the PCM is ... I know I need to connect the shift light to the white wire but knowing where the PCM is would help a lot. Thanks
Originally Posted by matt01z28
hey thanks a lot do you know where there would be a hole in the firewall ( to run the tach(green) wire)?
