po106
po106
tsp recently installed prc stage 1's and torquer 3 and im throwin p0106. they said to clean the maf sensor and see what happens. code went away for about 15 miles and came back. wont idle at all. do i need to get retuned or what? thanks. its an 02 TA.
The PCM has predicted values for the MAP sensor based on TP and RPM. The PCM will then compare the predicted value to the actual value. DTC P0106 is set when the actual value is not within the predicted range. Which tuning software is being used? In EFILive, you will want to go to {C3003} Predicted MAP Max and raise the values in the idle region.
thanks for the help. i checked everything before i got it scanned and checked again this morning when i read your post but couldnt find anything. so i just sent the pcm back to texas speed.hopefully they'll figure it out. thanks again
