Stalls when put in gear
I just installed a new cam,(its not a stock tune) The Hellion cam,243-247,629-629 112 LSA.I got it to idle pretty good in neutral,It hunts for idle alittle then settles down, But when I put it in gear it stalls out.If I give it alittle throttle it will stay running,And if I ease off the throttle it stays running in gear,So I'm assuming it wants more air.What can I adjust so it doesn't stall out when I put it in gear just to get me going so I can do an auto VE.I tried a few things and nothing seems to work.I have EFILive. 97 C5 w/ a LS7 short block,Patriot Perf heads,90/90,3500 stall,3.73's..................Paul
Originally Posted by Slowhawk
The lucky 97-98 Vette.
First thing I would do is raise the idle AIR table 10%. Seams to help Vette's alot.
Originally Posted by 2002_Z28_Six_Speed
Would you mind posting your direct airflow table?
I maybe am shooting in the dark but can you increase the desired shift time from N to D? Maybe that will buy the IAC motor time to adjust?
I saw some tables that might help the other day.
{B3629} Park to Drive Enrichment
Upon detecting a park/neutral to drive gear selection, value is subtracted from the commanded fuel EQ Ratio
There are a couple of other tables there for decay that you might want to play around with.
I bet that might help you out a litte.
