Vacuum leak effects on tune.
Old 07-10-2007, 10:45 AM
1hotls1's Avatar
Default Vacuum leak effects on tune.
During a recent dyno tune, the car made awesome power but on the way home I realized I had a bad vacuum leak. After fixing the leak, the car is down on power. My question is, could tuning with the vacuum leak be affected after the leak is stopped? The power reduction was pretty significant or I wouldn't even worry about it.
Old 07-10-2007, 10:51 AM
SSpdDmon's Avatar
Vacuum leak = unmetered air entering clyinders = lean condition
Plug the leak and the AFR should richen back up. You're probably running rich.
Old 07-10-2007, 12:58 PM
JoeyGC5's Avatar
With the gentlemen above
Old 07-10-2007, 01:09 PM
1hotls1's Avatar
Probably so, its not smoking but smells a little rich. I just wouldn't have thought the power loss would have been so noticeable.
Old 07-11-2007, 12:54 AM
1320FEVER's Avatar
too rich
Old 07-11-2007, 11:13 AM
KRAZY K 2000 TA's Avatar
of course your rich now you fixed the vacuum leak stoping the extra air from leaning it out,did you have it tuned with the vacuum leak if so it will need to be done again
Old 07-11-2007, 01:38 PM
1hotls1's Avatar
Yea, the leak wasn't noticed until I tried to turn on the a/c on the way home. I guess we'll retune it next week and see where the power went. How much can you lose by running rich? We also had to pull timing due to some knock on the dyno. Now that the vacuum leak is gone, maybe the timing needs to be adjusted. Thanks for the responses.
Quick Reply: Vacuum leak effects on tune.
