Opinions on timing needs for MSD/Carbed LS6
Old 07-15-2007, 02:06 PM
Ionize's Avatar
Default Opinions on timing needs for MSD/Carbed LS6
No PCM here, (at least right now...) but you guys know LS motor timing needs..
I've got a MSD/Carb setup in a 1800lb T-bucket.
The motor is as follows--Stock LS6 disp and compression, Ported 243 heads, 232/240 @ 609/595 cam, GMPP single plane intake, headers, 3400 stall convertor+ 350 turbo, 4.10 gears, basic heads/cam motor.
In the MSD box I've set a curve of 28* total in by 2300rpm, and 8* of vacuum advance above 6 inches of vacuum.
93 octane fuel. Seems to run pretty good, I'm in the process of dialing in the demon carb as well.
What are some of the timing amounts, etc that some of you carb/msd boxes are running?
Thanks!!
Old 07-16-2007, 05:07 PM
Ionize's Avatar
ttt, anyone?
