can anybody help with this??
Old 07-30-2007, 09:51 PM
1MEANGTO's Avatar
Default can anybody help with this??
i have an 06 gto that was tuned with ls2edit and the performance shop where it was tuned says they didnt lock the pcm, but efilive will not allow me to download the tune out of the pcm and the v2 is already licenced for the car. the pcm is a e40. does anybody know why this would be? thanks
Old 07-30-2007, 10:12 PM
Eurospec2's Avatar
If i understand correctly your trying to read the LS2Edit tune with EFI Live, and you have already Licensed your PCM with EFI Live?
Old 07-30-2007, 10:14 PM
wait4me's Avatar
It is for sure locked if ls2 touched it. The only way to unlock it is to put that computer back to stock using that ls2 cable i believe.
Old 07-30-2007, 11:13 PM
1MEANGTO's Avatar
yes thats right
Old 07-30-2007, 11:14 PM
1MEANGTO's Avatar
okay, thank alot
Old 07-30-2007, 11:15 PM
waterbug1999's Avatar
Hey, when you gonna do my tune..
Old 07-31-2007, 07:16 AM
LS1TECH Sponsor
foff667's Avatar
LS2edit by default locks the pcm...unless your tuner turned off the tunerlock function it will lock all pcm's so he might not even be aware of this fact.
Old 07-31-2007, 10:49 AM
wait4me's Avatar
I had recently a shop though, Send me 2 e38 pcms for me to flash that where supposed to be stock, They where flashed back to stock using ls2edit, they pressed the button to make it NOT lock the pcm, and when i got both here they where still locked.
Old 07-31-2007, 06:04 PM
1MEANGTO's Avatar
Well we won't be able to find out until friday thats when he's going there to get it unlocked
Old 07-31-2007, 09:35 PM
1MEANGTO's Avatar
Well now I am having the same problem with still no solution. If I can find out the ls2 edit seed key will efilive unlock it?
Old 07-31-2007, 10:28 PM
1MEANGTO's Avatar
Here is the answer I got from ken at carputing.
Mike,
The current LS2-edit locks by default, But the tuner can check a box
to not lock the file. We are working on a release that will unlock by
default and make the programmer select lock if needed. The default
setting has caused problems were tuners don't realize they are locking.
Any LS2-edit tuner can unlock the E40 ECM.
Ken
Old 08-01-2007, 03:39 PM
1MEANGTO's Avatar
I did get the ecm unlocked by the original tuner today and yes I can read the tune!!!!
Old 08-01-2007, 04:04 PM
Hey, how does that tune work that you want to put in my car? I thought only a timing tuner would do what you told me..
Old 08-01-2007, 04:54 PM
1MEANGTO's Avatar
No custom os with efilive will also do it.
Old 08-01-2007, 05:17 PM
1MEANGTO's Avatar
https://ls1tech.com/forums/nitrous-oxide/749133-flip-switch-nitrous-tune.html
look at that thread it has some info on what I used to make your tune.
Old 08-01-2007, 05:41 PM
From just reading a few posts... Its for a dry shot.
Old 08-01-2007, 06:28 PM
1MEANGTO's Avatar
You just zero out the added fuel and it will only pull timing and not add any fuel.
Old 08-01-2007, 09:59 PM
1MEANGTO's Avatar
Here this is the timing table used
Old 08-02-2007, 11:31 AM
DrkPhx's Avatar
Hey, you were the one bingeing all weekend.
Mike sent me the new COS and Cal but you need to tap into a PIN on the PCM to make it work.
Mike - Can you send me a copy of your 05 GTO stock file? I need the MAF table for my TB SS.
Old 08-02-2007, 12:23 PM
LOL.. Me? Never!!
You know what pin/wire it is? Maybe once I get moved and will be closer to everyone, we can do this one day. My car feels like a turd on motor!
