5.3L s10 on a 2002' 5.7 tune and injectors??
Old 07-31-2007, 11:51 AM
01WS6/tamu's Avatar
Default 5.3L s10 on a 2002' 5.7 tune and injectors??
I have an s10 that is a 5.3. Right now the computer is flashed for an 02 fbody and has the stock fbody 28Lb/hr injectors intake etc. I was going to get a dyno tune once it is up and running. But should the larger injectors and the IFR table for the pcm cause any troubles with the 5.3 until I can get it squared away enough to get the final tune done. I have a friend with hpt and we disabled the vats set everything for gears tires etc but left all of the engine and transmission tuning alone. Is there anything I should copy and paste to make it run for now for engine safety reasons? Thanks
Old 08-06-2007, 11:20 PM
01WS6/tamu's Avatar
up again anyone have some input. Not looking for concrete answers.
Old 08-06-2007, 11:35 PM
gametech's Avatar
Copy and paste the engine displacement and IFR and you should be OK for now. Since those tables are opposite each other in the stock tunes, it will probably crank up OK right now. However, it would be best to go ahead and modify them.
