Unplug Air Bag Sensor?
8 SEC SLOPPY SHOT!!!
Re: Unplug Air Bag Sensor?
if you disconnect it the only light that will be on is your airbag light. the box you are talking about is a airbag diagnostic module. thats the heart to the airbag system if you disconnet that no chance of
I'd like to know if I can install a toggle switch to disable the passenger air bag so my 5 year old daughter can ride in the front with me on a short trip to the store.
The single cab trucks have a key switch that does this.
I guess the bcm and pcm are interlinked with the air bag module i did'nt recall a ses light coming on but service light yes i forgot about that one. as far a hooking a switch up if you disable that bag you will get a trouble code and airbag system will not work and the light might have to be cleared to rearm the system. when the light is on system is dead.
This was told to my by a driving/safety instructor for Porsche when I was in Germany... I think it makes sense, so my child (6) has ridden in the front with the airbag. I just put her seat all the way back...
At one point GM dealers would install these shut-off switches free in the trucks because kids couldn't ride in the back.
That's why trucks get the shut-off switches now.
If you have 3 kids and can make the case that you have no option of using the back seat, they would probably install one for you (and I think it might be free)
FYI and FWIW, to have an ON-Off switch or disengage the air bag you have to make a request in writing to the NHTSA. See http://www.nhtsa.dot.gov/airbags/
I am going to call a dealer on Monday. If they make a switch then I have to install that if not then I will request to disengage it. My probably is I can't get better than 10 inches between my chest and the air bag.
